Minneapolis Moline Tractors Discussion Forum
not idlin smooth enough z
ralph
04-22-2004 16:18:31
rebuilt motor but idles a little rough and the govenor makes throttle erratick what is up thanks ralph and emma
Kelvin
04-23-2004 18:53:34
 Re: not idlin smooth enough z in reply to ralph, 04-22-2004 16:18:31
My best guess is there's trash in the idle circuit of the carburetor, or else its adjusted way too lean.
I'm assuming your Z has the Marvel Schebler TSX 97 carburetor:
The idle screw actually is an air bleed, so you screw it in to richen the mix, which it sounds like you need to do. Try screwing it in by 1/4 turn increments and see what happens. Be gentle-you'll run down tight on the seat in 1-1/2 to 2 turns.
Actually, sounds like your governor is O.K. usually they won't work hardly at all if there's much wrong with them.
