Minneapolis Moline Tractors Discussion Forum
Not a moline but the same color.......
Ryan
04-21-2004 18:48:36
I know this is not a moline but I would appreciate some insight. I have a yellow (like a moline) 77 cadillac that suddenly croaked off one day when I went to start it. It fired briefly and suddely quit, no spark. I have replaced the control module, coil, condensor, rotor, and cap and still cannot get spark out of the cap. I have even tried running a hot wire to bypass the ignition to no prevail. Am I missing something on these new fangled electronic ignitions? I can smell gas when I try to start it. Any ideas. I would like to get it moved but I don't now when else it could be. The rotor changes positions after I have tried to start it.
Ryan
Kelvin
04-23-2004 06:14:16
 Re: Not a moline but the same color....... in reply to Ryan, 04-21-2004 18:48:36
Assuming its an HEI distribuitor, Another thought is the pickup coil. It is down in there around the distribuitor shaft. use an ohmmeter, check for continuity at the plug, where it plugs onto the module. Then try wiggling the wires-sometimes they break, have continuity part but not all the time.
MikeinKY
04-21-2004 19:07:39
Check the timming chain.
