Minneapolis Moline Tractors Discussion Forum
New/old 445 and fluid changing questions
plummer p@lilly
04-19-2004 07:01:42
Couple of months ago I purchase and 56, 445. I have no history of this machine. I am in the process of changing all the fluids. What type of oil and hyd fluid should I consider to reduce and problems. Thanks, Choreboy, Semp Fi.
Husker Scott
04-19-2004 23:36:18
 Re: New/old 445 and fluid changing questions in reply to plummer [email protected], 04-19-2004 07:01:42
Choreboy,
I run 20W-50 engine oil in all my tractors. 8 quarts with oil filter change. No problem starting even to -20F last winter.
Transmission calls for 90w gear oil. 8 gallon without amplitorque, 10 gallons with. I used 80W-90 when changed last fall.
The hydraulic system uses regular ATF. The fill plate is behind/ under seat. Fill to within 1/2 of top.
Filters:
Oil= NAPA 1115 or Purolator L20110
Hydraulic (under seat, access from front)= NAPA 3110
HTH
choreboy0
04-20-2004 06:37:30
 Re: Re: New/old 445 and fluid changing questions in reply to Husker Scott, 04-19-2004 23:36:18
Asked and answered, thanks. Semp Fi.
