Minneapolis Moline Tractors Discussion Forum
G-706 Water Pump Removal
Waylon
04-14-2004 19:11:22
I need to take the water pump off of my G-706. I have removed all of the bolt and hoses but I can't get it pried off of the engine. Is there an easy way to do this? Thanks for your help.
ks
04-20-2004 10:22:09
 Re: G-706 Water Pump Removal in reply to Waylon, 04-14-2004 19:11:22
I dont have my book in front of me, but the 504 waterpumps have a bolt on the back side or a hidden bolt from the front, cant remeber which, but I had the same problem on my G1000. Seems like it may be a long bolt that you would not expect. If you have all the bolts out it should just fall off.
SWMolines
04-15-2004 11:51:50
It should pull right off. Are you sure you got all of the bolts? There is one way inside on the front that is hard to see and one that comes in from the back side down low.
