Minneapolis Moline Tractors Discussion Forum
Healthy 403
Mopower
04-14-2004 10:00:42
A G gasoline is rated at 58 h.p. @1100r.p.m.
What should be the horsepower of a 403 engine running about 8:1 compression and 1500 r.p.m. (otherwise all stock)? Any guesses here? Thanks MMotorheads!!!
jjmm
04-15-2004 03:25:30
 Re: Healthy 403 in reply to Mopower, 04-14-2004 10:00:42
my G 403 is bored .090 over, bigger carb, otherwise stock. put on dyno and set timing, got max. of 100 hp. pay attention to tuning you'll see good numbers. JR.
Andy
04-14-2004 16:04:59
I would guess you could pickup 15 hp, find a dyno to set the carb and timing; use some good gas or ethonal with that compression. If you get rid of the old heat exchanger manifold and use an M-5 style aftermarket or LP, that would help a lot(colder intake air)
Mopower
04-14-2004 16:35:23
 Re: Re: Healthy 403 in reply to Andy, 04-14-2004 16:04:59
I almost forgot. I have a LP intake and exhaust on it. Guessing 75 h.p. so I hope you're right. It is a power unit going in my old 47 UTU.
Ethan
