Minneapolis Moline Tractors Discussion Forum
1520 baler
Tractor Dan
04-13-2004 16:49:45
a while ago i posted looking for info on a baler its a 1520 i found a 1520 baler with 119 thrower it looks in good pritty good shape always been stored under cover was wondering if anyone has any info on this baler?? year, are they a good baler?? what is one in good shape worth?? it hasnt been used in 15 years anyways.
thanks for any info
james bodden
09-07-2005 10:30:29
 Re: 1520 baler in reply to Tractor Dan, 04-13-2004 16:49:45
As i recall, my Grandfather owned one and it baled 10,000 + bales for nearly 30 years before the gearbox finally went. If they ever put the effort to change the gear oil, it might have lasted longer. Only problem i ever recall having, was driving too fast and the baler would get plugged. However, this baler has a hatch next the knotter that would allow you to pull out the hay, rather than reach from the front of the baler to untangle things. Baler by and large worked well, but saw more of them labelled as the Oliver equivalent. I also believe it was the last baler badged under the MM emblem before white took over.
