Minneapolis Moline Tractors Discussion Forum
BF Plow mounting brackets
Steve Sewell
04-11-2004 19:30:40
Does anyone have the True Draft plow set-up on their MM BF? I'm tring to get mine on and am doing something wrong (I have no manual for the plow). I can't get to it lift correctly. Need to know how long the chain needs to be on the right hand lift rod. Also which frame rail holes to mount the bracket on the left side that clamps to the lift cross bar.
Thanks!!
- Steve
Steve Sewell
Albany, Ohio USA
[email protected]
Brian
04-11-2004 23:08:38
 Re: BF Plow mounting brackets in reply to Steve Sewell, 04-11-2004 19:30:40
Steve, I believe I have the Plow Manual for your B.F. When would you like to meet up??? Give me a call. Early Mornings are best. (Boy this one will cost you) Brian..... .
Keith Ault
04-14-2004 19:05:59
 Re: Re: BF Plow mounting brackets in reply to Brian, 04-11-2004 23:08:38
I have a manuel also,about 40 mile away,Chillicothe ,let me know ,will run down,Keith Ault
Steve Sewell
04-15-2004 18:51:14
 Re: Re: Re: BF Plow mounting brackets in reply to Keith Ault, 04-14-2004 19:05:59
Keith: Forgot to tell you that you have seen my BF before. It was the lone MM , I think, at the Avery show you had at the fair grounds over your way several years ago.
- Steve
Steve Sewell
Albany, Ohio USA
[email protected]
[email protected]
Steve Sewell
04-15-2004 18:46:34
Brian and Keith thanks for the offers. I got it straightened out. Helps if you mount the lift bracket on the tractor in the correct place. (-; I have an Avery plow book but Moline changed the two lift brackets that attach to the lifting cross bar. So they were not shown. However I found a "before" picture of the teardown that showed the error of my ways. Both of you are more than welcome to drop over to take a look at it. Just call to make sure I will be around.
- Steve
Steve Sewell
Albany, Ohio USA
[email protected]
[email protected]
