Minneapolis Moline Tractors Discussion Forum
335 Industrial differences from regular 335
runmplsmanmn
04-10-2004 07:30:52
Does anyone know the differences on a 335 Industrial tractor from a regular agricultural one? Do they have a different color scheme?
runmplsmanmn
04-13-2004 14:16:07
 Re: 335 Industrial differences from regular 335 in reply to runmplsmanmn, 04-10-2004 07:30:52
Thanks for the info. I have seen one that did not have a lot of the differences listed by JK but had the Industrial Serial number plate??
JK
04-13-2004 18:06:15
 Re: Re: 335 Industrial differences from regular 33 in reply to runmplsmanmn, 04-13-2004 14:16:07
Keep in mind that these tractors are pushing 50 years old. Some of them may have had parts replaced with parts from other tractors. For instance, I have a 335 Industrial with a tranmission and rear end from a 335 Utility that was replaced as a unit when a previous owner tore up the rear end (differential).
Also MM seems to have made numerous specials with apparently whatever was available that a customer wanted on them.
JK
Ryan
04-10-2004 08:14:09
My industrial does not have torque, power steering, or a drawbar (had a mounted cycle mower). It was a state of Miss road tractor and also did not have fenders that I know of.
Ryan
JK
04-10-2004 07:56:56
The main differences I know of are the industrials have:
1. an I beam type front axle
2. front wheels w/cast centers & clamp on rims
3. frt axle mount bolts where weight bracket goes
4. frt casting same as utility (bushings not bearings for steering sector)
5. most have no 3 point system
6. most have larger industrial hyd pump
7. rear axles/wheels have 12 bolts instead of 6 8. some have a foot throttle also
9. many of them had a shuttle instead of torque
John
