Minneapolis Moline Tractors Discussion Forum
HOW ABOUT THAT MM Z QUESTION?
Glenn FitzGeral
04-06-2004 06:53:32
I'm still hoping for that information. Thanks Glenn F.
Jim Parisot
04-06-2004 13:45:51
 Re: HOW ABOUT THAT MM Z QUESTION? in reply to Glenn FitzGerald, 04-06-2004 06:53:32
Glenn,
I'll assume you are referring to the ZT tractors rather than the later ZA and ZB. Skipping past the "37 in '36" production started in 1937 with the ZTU and ZTN and the ZTS which had it's own serial number range. Production went till 1947 on the ZTS and to 1948 on the others, which by 1947 included the ZTE. There were a handfull of industrials made in the early years. Tested at Nebraska the Z made 25.2 h.p. at the belt on distillate and 30.55 on gasoline. The tractors weighed about 3700 lbs., varying with type and equipement. They could be had on steel or rubber, and never had a foot clutch or live power. The older tractors are a little more popular because they look neater with the cast front and rear wheels with demountable rims as opposed to the later stamped steel wheels. The early tractors had the full flat top fenders which changed to the full crown in 1938 I believe and then the later tractors changed to the clam shell in 1945. The early tractors also had the air intake on the left side of the hood and looked neater too as they had a taller stack. In 1940 the air cleaner and short stack were moved to the right side of hood. Curt gave you a good overview of the ZT vs. later ZA's and ZB's, but the ZT's were always known as such, albeit people just referred to them as Z's. Hope this helps.
Jim
Kevin Moschenrose
04-06-2004 22:01:47
 Re: Re: HOW ABOUT THAT MM Z QUESTION? in reply to Jim Parisot, 04-06-2004 13:45:51
PSSSST: Jim also the early ones had the red face open wire type grills in them as well. ZA's & B's did not. :) Good to see ya posting!
Curt Cooke
04-06-2004 08:29:42
Glen, I'm a Minnie novice so don't repeat whatever I have to say with authority. The Z production started in the late thirties I think and with some changes in form, continued into the mid fifties. The original Z became known as the ZT when the ZA was introduced. There wasn't alot of difference between the tractors, distinguishing features were the exhaust exit, fender design and shifter location. The ZA was replaced by the ZB in about '53. The ZB had a higher operators platform, foot clutch and a power-release feature which provided a pseudo-live PTO. That's a start and should draw the attention of a crowd.
