Minneapolis Moline Tractors Discussion Forum
Oil leak
Tim
04-03-2004 16:15:18
HI guys, been running my tractor for about 2 weeks now (thanks for all of your help} 1948 UTIL i noticed some oil leaking from a hole {factory hole it looks like}on the bottom of the block is this normal or do i have problem.
Kevin Moschenrose
04-04-2004 09:59:59
 Re: Oil leak in reply to Tim, 04-03-2004 16:15:18
Oil leaking is always a problem how big is the real question? If you mean the factory hole under the bell housing and just under the clutch/flywheel, it is one of two types of oil. The first one is engine which means the rear main is going out and the second one is the input shaft seal to the transmission is going out. Either case it will spell trouble for the clutch and pressure plates as well.
