Minneapolis Moline Tractors Discussion Forum
Rear hubs
JIM TURNBULL
04-01-2004 17:00:02
Need a pair of rear hubs to fit my 1953 moline UB. I am changing to 9 hole factory rims for tractor pulling.
Taylor Marret
04-12-2004 17:58:50
 Re: Rear hubs in reply to JIM TURNBULL, 04-01-2004 17:00:02
Byron Emmick sells weld on hubs which are much lighter than any stock ones I have seen. only do this if you are going to 9 bolt from now on as welded is not too easy to change. His number is 270-295-3331
E J
04-01-2004 18:51:55
I used a pair of 3010jd hubs with a home made shim out of drive shaft tube to take up the difference in axle diameter.
