Minneapolis Moline Tractors Discussion Forum
ZA not running
Todd
03-31-2004 11:13:33
I'm gathering ambition to begin restoring my grandfather's ZA. Right now, there's no spark. I had the coil tested, and it was fine. To keep things simple, is this a positive or negative ground setup?
JC
04-06-2004 13:23:23
 Re: ZA not running in reply to Todd, 03-31-2004 11:13:33
Be sure not to neglect spark plug wires. Make sure you replace your wires with wire core. Never use carbon trace spark plug wires as they will not work.
Chris
04-01-2004 09:55:11
I had this problem with mine. I bought it and it had little to no spark. You probably just need to clean the points and rotor and maybe install a new condensor. I replace the entire electrical system, minus distributor bottom, starter, lights, and things like that and it was under $60. Good luck.
Kevin Moschenrose
03-31-2004 22:19:38
A bad condensor will cause this as well.
Brian (MN)
03-31-2004 21:05:38
Todd, It is positve ground and 6 volt. When tractors sit around a few years you'd be surprised at all the things that go bad. First I'd check the points, sometimes they will corrode, a little filing might clean them up. If not, start following the current around with a volt/ohm meter, check wires for breaks, connections,and switches, Sooner or later you'll get spark.
Brian (MN)
JKC
03-31-2004 16:19:03
The ZA is a positive ground.
