Minneapolis Moline Tractors Discussion Forum
Need identity of tractor
Garry
03-30-2004 07:48:47
third party image
I have a MM and was told it was a U model made in the 50's. The seriel number is partially gone but it starts with the numbers 019. The tag has the letter U. Looking at the numbers listed on this site something doesn't match up. Any help is appreciated.
joan bonham
03-31-2004 08:22:29
 Re: Need identity of tractor in reply to Garry, 03-30-2004 07:48:47
need to know year of utu model 321630u need to know year of utu model 337045u
need to know about 445-B1 model 10101662
and a 4 star 16600343
any information about these would be deeply appreciated, year of manufacturing, any other detail would be wonderful thanking you in advance...joan...
Bobby Kenner
04-04-2004 11:47:43
 Re: Re: Need identity of tractor in reply to joan bonham, 03-31-2004 08:22:29
would like information on a minn.moline I have.
the s.n. 401210 model EE
Jim Parisot
04-04-2004 21:43:29
 Re: Re: Re: Need identity of tractor in reply to Bobby Kenner, 04-04-2004 11:47:43
Bobby,
You've given us the engine serial number, but the tractor serial number should be close. That would make your tractor a 1939 RT square tank. The tractor serial number is on the right side of the transmission case just to the left of the belt pulley housing. Wish the tractor were mine.
Jim
BMG
03-31-2004 13:48:56
Joan,
There's a serial number reference link on the far left column but here's what you've got anyway:
321630u 1945
337045u 1947
10101662 1956 445 Universal
16600343 1959 4 Star
Brian
joan bonham
04-01-2004 03:58:57
 Re: Re: Re: Need identity of tractor in reply to BMG, 03-31-2004 13:48:56
just want to thank BMG for his or her information this is wonderful, do not know how you know these things from a number but dad will be glad to know. and receive this info..thanks again. BMG joan.
Bill
03-30-2004 16:11:58
It is definitly a U and from the looks of the hood and manifold it was an LP version. The tank would appear to be either a Z or an early u tank that has been made to fit.
Kelvin
03-30-2004 18:53:25
 Re: Re: Need identity of tractor in reply to Bill, 03-30-2004 16:11:58
The tank is correct for a gasoline U. The only difference between a ZA tank and a U tank is the outlet. They are physically the same size. the reason it looks odd is the hood was made to fit the lp tank that was on it at one time.
split-block (283) U's were made between 1948 and 1953. I'm betting yours is a '48 or '49 model. The serial number tag should be on the right side of the transmission case, above the belt pulley.
BMG
03-30-2004 13:52:46
Garry,
'019' is the start of a serial number for the engine (283A-4) from 1948 through 1953. Look on the right side of the trans housing right above the belt pulley drive for the tractor serial number.
Brian
L. Miller
03-30-2004 11:21:10
You need to see if you can clean up the the area better. UB special 1955 according to my book starts 09 but the only other thing thats close is a UTC that starts with 015. I could help more with more info,sorry about the educated guesswork, I hope you will save the beautiful machine!!!
