Minneapolis Moline Tractors Discussion Forum
UTS pulling strategies
Moliner
03-29-2004 16:12:12
Im interested to hear strategies of the uts pullers here. New to the sport and would like to here your stories from hitch to full pull. thanks
Moliner
03-31-2004 07:18:17
 Re: UTS pulling strategies in reply to Moliner, 03-29-2004 16:12:12
I pull a dead weight sled, and when i have practiced in the past i use 2nd or third gear, most sucsessfully 3rd gear. So just get the rpm's up and let'er rip? or mid range rpms? just looking for tips like that also. thanks guys!
BLT
03-30-2004 18:52:18
I have been pulling a UTS for 1 year and here is a little something I stumbled onto, a wheatland tractor is front heavy, so I lengthened my drawbar 10 inches and that puts more weight on the rear, front end will come off the ground a little and it would not do it before, I beleive that it has helped.
BLT
04-01-2004 06:27:41
 Re: Re: UTS pulling strategies in reply to BLT, 03-30-2004 18:52:18
I have new Firestones and they are not cut.
wendel
03-31-2004 19:47:18
Are you guys using cut tires or not? I have a hard time keeping the front of my UTS on the ground.
Kelvin
03-30-2004 19:00:21
I agree that a UTS is front heavy. any weight should be added either ahead or behind the rear axle. I've seen UTU's that did well with almost all their weight just behind the bell housing joint.
BLT
03-30-2004 19:15:56
 Re: Re: Re: UTS pulling strategies in reply to Kelvin, 03-30-2004 19:00:21
I have my weights mounted right in front of the rear wheels and some smaller weights in front of the seat, there's just not any room to put weights behind the wheels.
