Minneapolis Moline Tractors Discussion Forum
proper way to adjust r series govenor
ralph
03-25-2004 17:08:08
I put a z motor in an r and an having trouble adjusting the govenor realy had to bend linkage to get it right above the throttle when they are both wide open and I cant get it to idle down all the way any help is appreciated amd it does not seem to rev up all the way
ralph
03-27-2004 04:45:54
 Re: proper way to adjust r series govenor in reply to ralph, 03-25-2004 17:08:08
hi I am using the spacer from an r and I am using a z carb I also have a lp manifold if that makes a diferance really had to bend the linkage because the linkage was at least a 1/2 inch long.
thank you in advance Ralph
Kelvin
03-26-2004 18:23:43
which drop tube are you using? If you've got an R drop from the manifold with a Z carb on it, the link will be way too long, because the R tube is longer to make up for the smaller carburetor.
With no worn parts anywhere in the governor, you shouldn't have to bend that rod at all.
