Minneapolis Moline Tractors Discussion Forum
V4 air cooled motor on MM L combine
Kruse
03-25-2004 16:44:15
Went junk yard scrounging today and enjoyed the
weather. Found an old salvage yard that I think
is pretty much forgotten in this area.
Anyway, I came across several MM "L" combines that were pretty much complete. What I thought was interesting was the motor in these. They have a (I believe) MM built V4 motor similar to the old Wisconsin motors. Now correct me if I'm wrong, but I think there were two separate motors in these combines. I think I saw a motor with the spark plugs on the outside of the "V" and I think I saw one that had the spark plugs on the inside of the "V". Am I mistaken about that? (I had to really rush through the salvage yard; I couldn't stay too long in one area) The motors seemed to be complete.
Do these have any value? I'm sure they weigh a ton, but looked to be real interesting.
G. L. Grumpy
03-25-2004 18:13:01
 Re: V4 air cooled motor on MM L combine in reply to Kruse, 03-25-2004 16:44:15
I'ld love to see a whole one, and you say SEveral? Where you at? I'm in INdiana. I'ld like to have one just cause they are different!
Kruse
03-26-2004 03:46:09
 Re: Re: V4 air cooled motor on MM L combine in reply to G. L. Grumpy, 03-25-2004 18:13:01
I think one combine looked complete or nearly
complete. I guess I meant to say that the ENGINES were complete. Anyway, I think the three engines were all complete. Now, did I see two different air cooled engines, or was I mistaken? I am located in far north Kansas and am an Oliver man myself. I recently purchased an Oliver 70 and cornpicker from this man and was just looking through the whole yard.
BMG
03-28-2004 17:19:30
 Re: Re: Re: V4 air cooled motor on MM L combine in reply to Kruse, 03-26-2004 03:46:09
Kruse,
The engine was built by Moline. The early versions had the cylinders from a ZA engine mounted in a V. I don't remember if the plugs were on the inside our outside. I've got one of those engines from a parted out L down the lane. I'd have to go look at it to be sure. The later Unis had a slightly different V engine based on the 445 tractor motor. Both of these V motors were liquid cooled. I've got 2 complete Unis (L). I'd probably sell one if someone was interested. I think the motors are stuck from sitting though. I've got a couple combines and picker/shellers attachments for these too. These can be difficult to haul due to their width. I'm in SE Michigan. Drop me an email if you want to know more.
Brian
