Minneapolis Moline Tractors Discussion Forum
445 3pt Hitch and Hydraulics fit on 335?
runmplsmanmn
03-23-2004 19:17:27
Will the hydraulic assembly and 3pt hitch from a 445 fit on a 335?
JK
03-24-2004 05:59:18
 Re: 445 3pt Hitch and Hydraulics fit on 335? in reply to runmplsmanmn, 03-23-2004 19:17:27
The 335 3 point is category 1 while the 445 is category 2. You may be able to make the lift arms & linkage work but they are different.
The pump will work but may need different adapter to connect the pump to the shaft.
The main casting under the seat is completely different. The 445 mounts with 4 short 5/8" studs while the 335 mounts with 4 1/2" longer bolts that go through the casting into the rear end casting. The bolt pattern is different and I'm fairly certain that the location of the inlet and outlet for the pump are located in different places with respect to the mounting bolts.
The piston, rod and cylinder are smaller and designed different for each one.
The control valve and most associated parts are the same although some of the linkage is different.
Best bet is to look for a 335 unit.
John
Kelvin
03-23-2004 19:25:08
Pretty sure the 3-point lower arm mounts won't fit the 335 rear, its a different casting from a 445.
I'm also thinking that the reservoir/lift arm assembly has a smaller bolt mounting pattern on a 335.
The pump will probably work, though. Probably some of the control valve parts interchange. . .
