Minneapolis Moline Tractors Discussion Forum
Battery Cable
Lucas
03-18-2004 05:28:08
Where do you guys get the big battery cables for 6 volt batteries? I was thinking of a welding supply store. Thanks
STEVE
03-18-2004 08:35:05
 Re: Battery Cable in reply to Lucas, 03-18-2004 05:28:08
NAPA OR PARTS STORE.
USE OUGHT IF YOU CAN GET IT.
1 GUAGE HOWEVER SHOULD BE SUFFICIENT. USING 2 BATTERIES IN PARALELL DOUBLE OUGHT
A GENERATOR SHOP WILL MAKE YOU A CUSTOM SET
AND SOLDER THE END CAPS. OR YOU CAN BUY THE
WIRE AND SOLDER YOUR OWN. THE DAMN THINGS ARE EXPENSIVE USUALLY A GENERATOR SHOP IS CHEAPER THAN THE PARTS STORE. GOOD LUCK
