Minneapolis Moline Tractors Discussion Forum
Distributor ?
Doug
03-12-2004 04:37:55
I have a 220 power unit L.P.the distributor is #1112660 some of the after mkt. part books show this dist. for a 670 L.P. & for a u302 1112671 the old dist. is beyond repair,which one do I need.
Dale
03-13-2004 13:20:53
 Re: Distributor ? in reply to Doug, 03-12-2004 04:37:55
Does your distributor have clips or screws for cap holdowns? Either way we can help you, Dale, 920 295 3278 or [email protected]
Kelvin
03-13-2004 06:02:37
1. Unless you have a lot of water damage, its probably not hopeless. That distribuitor uses lots of the same parts as a similar year chevy vega. (And for some reason, the points are cheaper at NAPA).
2. If you have to have a distribuitor, A Delco 1111711 from a Z, ZA, R, 335, 445, jetstar, 4star and some jetstar3s should work.
