Minneapolis Moline Tractors Discussion Forum
Question about MM
Tim
03-10-2004 19:33:35
When looking for parts(points spark plugs ect.]for my UTIL in the vaul-bilt catalog ther are parts listed for a UTU will these parts work on my UTIL
Unimog
03-11-2004 18:47:45
 Re: Question about MM in reply to Tim, 03-10-2004 19:33:35
Should be the same as the UTU
Kelvin
03-11-2004 18:45:06
If your UTIL is military and still has the waterproof ignigion system, The answer is no.
For points, it depends on whether your tractor has a magneto or distribuitor. It should be the same point set if its a distribuitor.
For plugs, if your heads have 7/8" spark plug threads, Champion W10 or Autolite 3076 work well (The Autolite seems to always bee cheaper)
If your heads are 18mm spark plug thread, Champion D21 or Autolite 386 is about right.
If you look at aftermarket parts books long enough, you'll see tractors listed as U, or UT, or UTI at different places.
