Minneapolis Moline Tractors Discussion Forum
Flywheel ring gear
Tractor Rod
03-10-2004 04:00:58
Need to find a flywheel ring gear for a M5 moline. It is gas. AGCO no longer handles them. Thanks Tractor Rod
John G
03-10-2004 21:51:45
 Re: Flywheel ring gear in reply to Tractor Rod, 03-10-2004 04:00:58
some where in the past on this forum, there was a website for ring gears, if you can't find it, MAYBE I can find he sheet I printed out on it.
Andy
03-10-2004 15:14:41
If they are similar to a U or a Z flywheel ring gear, you can heat them,(ring gear only)up, take it off, give it 1/4 turn and put it back on. We've done this to several U's and Z's that were wore very bad. A four cyl usually stops in one of two places. You can tell by the worn teeth on the ring gear. Once the starter is ingaged the worn teeth don't seem to cause much trouble.
JC
03-10-2004 15:01:46
If you cannot find a replacement, yours can be built back up by a good machine shop.
Curt Cooke
03-10-2004 06:28:15
Gas or Diesel? What's wrong with yours? Is yours ruined beyond repair or is it gone?
