Minneapolis Moline Tractors Discussion Forum
Oil pump too tight?
Ray
03-09-2004 06:47:23
I put my oil pump on my U302 last night, and it makes the engine very hard to turn. When I loosen the oil pump bolts the engine turns free again. Do I need another gasket for a spaceer, or will it loosen up on its own?
Also, my gasket kit did not come with seals for cam shaft bearing oil supply line. Did I get jipped, are these seperate?
Thanks,
Ray
Kelvin
03-09-2004 17:50:08
 Re: Oil pump too tight? in reply to Ray, 03-09-2004 06:47:23
I just overhauled a jetstar engine, which is very similar.
You need .001-.004 side clearance on the pump gears. I had to use 2 gaskets on mine, (Each gasket miked .004) the set only came with one. Fortunately I had one left over from a Z set that was the same. (The set should have had at least 2 of those gaskets) I had to re-use my old camshaft seals, too. I also didn't have enough 0-rings for the water passages in the heads and blocks.
Also, the oil supply tubes need O-rings on them where they go into the oil passage in the block, had to get some out of the assortment at NAPA.
Did your gasket set come from NAPA?
Ray
03-10-2004 06:31:58
 Re: Re: Oil pump too tight? in reply to Kelvin, 03-09-2004 17:50:08
I got the set from Welters. It is an agco set.
Thanks for your help.
Ray
