Minneapolis Moline Tractors Discussion Forum
DIESEL QUESTION
MATT
03-08-2004 10:59:03
WILL THE JUGS AND HEADS OFF OF A G-900 DIESEL FIT ONTO A UB DIESEL WITHOUT ANY MODIFICATION? WILL THE PISTONS OUT OF A G-900 FIT RIGHT ONTO THE UB ROD AND HAVE THE SAME COMPRESSION HEIGHT? THANKS
Bill
03-08-2004 15:26:45
 Re: DIESEL QUESTION in reply to MATT, 03-08-2004 10:59:03
Yes they will fit without modification they both have the same wrist pin size. So will the G1000 blocks and pistons or you can bore the 900 blocks out and use 1000 pistons in them as well. Just remeber the rods will not pass through the bore until you are .060 over the G1000 size of 4.625
Mopower
03-08-2004 13:11:10
I know the jugs will go right on. I am running G900 blocks on mine at about 300 cubes. Runs pretty good. Not sure what pistons are in it, but I will find out for ya. I have some tuning to do on this. It has a 5star pump and injectors and the timing is just a little off.
Mopower
03-09-2004 04:56:21
 Re: Re: DIESEL QUESTION in reply to Mopower, 03-08-2004 13:11:10
Yes mine has G900 pistons.
