Minneapolis Moline Tractors Discussion Forum
appropriate carb/venturi setup?
Mopower
03-08-2004 08:34:55
Hello fellas. I'm getting my stock G engine ready to install in my old 47' U. Right now I have a nice U carburetor. It is my understanding that a G carb has a bigger throat AND venturi. On this stock 403 engine, what size venturi should I put in if I use the smaller throat U carburetor? Can it still perform normally with the smaller U carb and larger G or M670 Super venturi? Your thoughts fellas...
Kelvin
03-08-2004 17:26:43
 Re: appropriate carb/venturi setup? in reply to Mopower, 03-08-2004 08:34:55
I think the main difference between a 403 carb (tsx68) and a U (tsx67) is the throttle shaft and the venturi. If its stock, just use the 403 venturi in the U carb and it should be O.K.
If you have the original 403 carb, just rebuild it-that would be ideal. The second best alternative is to put the 403 venturi in the U carb.
Mopower
03-08-2004 17:32:03
 Re: Re: appropriate carb/venturi setup? in reply to Kelvin, 03-08-2004 17:26:43
That is probably what I'll do. The 403 is a power unit that ran on Nat. Gas. So no carb, but I got a very nice U carb so whet the heck, it can look stock till I get a better one. Of course the pierce governor will help. Hee hee.
