Minneapolis Moline Tractors Discussion Forum
Help with installing oil pump drive in U302
Ray
03-08-2004 07:13:33
I am rebuilding a U302 gas. When I removed the oil pump drive shaft I failed to mark the the slot position before removing it. How do I determine the correct position so the the timing will be close.
thanks,
Ray
Kelvin
03-08-2004 17:17:59
 Re: Help with installing oil pump drive in U302 in reply to Ray, 03-08-2004 07:13:33
IF you lost your original position, it looks like you will have to reset the timing just as if you were timing a new engine.
Crank the engine until #1 piston comes up on compression.
Install the shaft so that the distribuitor rotor button will point to the #1 contact in the cap. This will get you close, you may have to turn the distribuitor some to get the correct timing for starting.
Ray
03-09-2004 06:37:53
 Re: Re: Help with installing oil pump drive in U30 in reply to Kelvin, 03-08-2004 17:17:59
thanks for your help
