Minneapolis Moline Tractors Discussion Forum
value oiling
Spuds
03-07-2004 11:10:25
After rebuilding my Za 206 engine I ran her for a while but notice no oil was dripping from the value oiling nails, Now, not knowing very much about this engine( this is the first time I've done anything with a antquie tractor)I turned the engine over with the starter to prime the oil system, before starting it.Did I miss something? Suggestion very welcome.
Thanks Spuds
Kelvin
03-07-2004 18:58:03
 Re: value oiling in reply to Spuds, 03-07-2004 11:10:25
Some things you can check:
I'm assuming you have good oil pressure at the gauge.
See if that little tube brazed in the center bearing oil line is open. If you remove the plate over the little oil gallery just above the side cover (has 2 stove bolt screws in it) does oil come out there? Does the gasket you put behind that plate have 3 holes in it so oil can circulate? It has to go through the gasket, into the V notch in the plate and back out the outer 2 holes.
If you take pliers and twist those nails, does that open the hole enough to drip?
