Minneapolis Moline Tractors Discussion Forum
Running PTO Implements with a UTS
JC
03-02-2004 18:58:59
I am planning to use my UTS this next hay season.
I have a factory manual for the tractor and it says that the PTO Speed is 575. All of my PTO imlements are 540 and state in their manuals that under no circumstances should you exceed 540.
What is really strange is that the implements are also Minnieapolis Moline from the same era!
What do you reccommend?
Roger (in Ks)
03-02-2004 21:53:00
 Re: Running PTO Implements with a UTS in reply to JC, 03-02-2004 18:58:59
One of my prize possessions is a book from Oliver that tells all of the tractors actual PTO speeds. 540 must have been a general or "get as close as you can" speed. Tractor PTO speed ranges from 380 RPMS all the way to 740 RPMS. Crawler PTO speed was very slow, sometimes dropping to 250 RPMS. As long as the implement doesn't jump up and down and try to self-destruct you are ok. The book I have also tells the speed of the flat belt pulley. It was measured in feet per minute.
Roger
03-02-2004 20:05:59
Just run the engine slightly slower than wide open if you feel you need to. I wouldn't worry about it myself though.
