Minneapolis Moline Tractors Discussion Forum
Need Help!!!!!!!!
brandon
03-02-2004 08:03:05
I am wanting to get rid of the front cast wheel on my mm gtb and get smaller wheels and tires does anybody know will a hub off a u fit or as anybody else done this and have any suggestions of what type of hub or wheels and tires to use.
Thanks Brandon
Curtis
03-03-2004 09:58:34
 Re: Need Help!!!!!!!! in reply to brandon , 03-02-2004 08:03:05
The later steel front axle has hubs for 6 bolt pressed steel. I don't know if these hubs fit the cast hub spindles. If you are interested in replacing the whole front axle, I have one I would sell.
James Snow
03-02-2004 18:02:11
If you are looking for smaller tires,you might want to try some of the spacesaver spares that come in newer model cars they are fine for pulling and are light and will lower the front end about two inches.
My local CO-OP gave me new spacesavers they had replaced for customers and just charged for the mounting, Good luck.
Bill
03-02-2004 17:25:54
I put some u hubs on a G a few years ago i went to the brg supply and got the smallest od race that would fit the G brg then machined the u hub to fit it. I believe i also had to space the brg out a little from the spindle. I didnt use a seal just the dust cover but since it was just for pulling i didnt think it would matter.
Steve
03-02-2004 14:27:36
BRANDON,
I'M NO EXPERT BUT I BELIEVE ALL YOU NEED TO DO IS MEASURE YOUR BOLT PATTERN AND GO LOOKING. I HAD NO TROUBLE FINDING STEEL WHEELS IN JUST ABOUT ANY SIZE & WIDTH (FAIRLY CHEAP).
Steve
