Minneapolis Moline Tractors Discussion Forum
MM GB
ron
03-01-2004 16:44:44
Can you put 800 jugs and pistons on a GB?
How?
Andy
03-02-2004 13:55:50
 Re: MM GB in reply to ron, 03-01-2004 16:44:44
I checked into it,(but haven't done it). It takes a lot of grinding on the crankcase holes to fit the blocks. The other issue is piston/ rod combo. If you use 800 pistons on 403 rods you have to bush the wrist pin down to 403 size. other wise you may have to go with custom pistons or rods. 800 blocks are a bit taller. You may need longer head bolts and pushrods.
Bill
03-01-2004 18:52:12
Find someone who does that kind of work and let them do it.
