Minneapolis Moline Tractors Discussion Forum
Rearend locked up ?
Mike
02-29-2004 16:10:27
Have a G VI that was fine when parked has set 5 or 6 years ? was in side and now the rearend is locked up any help on what to look for ? don t know much about G VI
John G
02-29-2004 17:38:41
 Re: Rearend locked up ? in reply to Mike , 02-29-2004 16:10:27
You don't mention where you are, is it below freezing? That can cause the same problem, just a thought.
Mike
02-29-2004 20:13:33
 Re: Re: Rearend locked up ? in reply to John G, 02-29-2004 17:38:41
No its warm here motor turns over hasen't run it ? but have pulled it feels like it shifts gears but both tires just slide took brakes off still dosent turn
John G
03-01-2004 06:38:47
 Re: Re: Re: Rearend locked up ? in reply to Mike, 02-29-2004 20:13:33
Mike, I'm just trying for the easy fixes, have you tried to push it backwards? The brakes could be stuck, I think it has discs, the ball or balls could be rusted on the ramp, maybe a tug backward would free it.
Mike
03-01-2004 10:58:59
 Re: Re: Re: Re: Rearend locked up ? in reply to John G, 03-01-2004 06:38:47
Had taken the brakes of and they were ok Left them off and pulled it forwards and backwards ? Going to have to take top off trans and look in side
Jim Parisot
03-01-2004 12:02:20
 Re: Re: Re: Re: Re: Rearend locked up ? in reply to Mike , 03-01-2004 10:58:59
Mike,
I think that is the right avenue to take, it sure sounds like you've got the tractor in 2 gears.
Jim
ron
03-01-2004 14:44:34
 Re: Re: Re: Re: Re: Re: Rearend locked up ? in reply to Jim Parisot, 03-01-2004 12:02:20
If you parked it on a hill, the gears could have slid into wrong position. This happened to a farmll H I had.
