Minneapolis Moline Tractors Discussion Forum
MM 97
novice
02-26-2004 16:07:47
I recently purchased an MM 97. The clutch gave out loading it onto the trailer. I was told it was the "shifter ring" that broke. From the MM-19 IT manual (page 64, Fig 167, part # 22) it looks like it comes in 2 half circle pieces. I was told it could be installed through the 4 bolt access plate on the side of the transmission without splitting the tractor. Does anyone have any experience at this??
Gbb
02-27-2004 05:31:02
 Re: MM 97 in reply to novice, 02-26-2004 16:07:47
The only thing you can change through the side plate is the two piece throw-out bearing. All the other clutch components have to be serviced by splitting the tractor. The side plate opening was used to grease bearing or to adjust clutch. Spitting is awkward and cluch parts are hard to find.
Ryan
03-02-2004 11:17:16
 Re: Re: MM 97 in reply to Gbb, 02-27-2004 05:31:02
Do you know if the clutch components were manufactured by twin disc? I worked on a tc mta that had these components and they are still available.
Ryan
