Minneapolis Moline Tractors Discussion Forum
445 hydrualic oil
mike
02-26-2004 11:40:07
my 445 book says that i am to use automatic transmission fluid for the hydrualic system. i just got this tractor, and it's the first of it's kind for me, but wont i mix tranny fluid and hydrualic fluid when i hook up to implements? the tractor now has what appears to be hydrualic fluid in it, and the power steering does not work well at all and neither does the three point. any suggestions would be greatly appreciated.
Dale
02-26-2004 15:53:20
 Re: 445 hydrualic oil in reply to mike, 02-26-2004 11:40:07
When these tractors were built ATF was the only available fluid with the qualities for the hyd needs of these tractors. Now we have many choices and any good hyd fluid will serve the needs of these systems, and usually less cost than ATF. If your hyd system is worn to the point of less than desired performance there isn't any fluid that will build it back to OEM standards, but you may only have some relief valve weakness, what pressure is your tractor putting forth? Dale
