Minneapolis Moline Tractors Discussion Forum
335 MM or 445 MM UTILITY WANTED
ng
02-19-2004 18:05:23
Where can you find a good running 335 or 445 MM Utility to use? Thanks
Scott
02-23-2004 19:43:52
 Re: 335 MM or 445 MM UTILITY WANTED in reply to ng, 02-19-2004 18:05:23
ng,
I have a 1957 445 utility that is restored. Runs like a top, repainted, live power, 3pt. power steering. I bought it a couple years ago thinking I would use it more and wanted something with a loader. I need to sell this one before I buy a tractor with a loader or my wife will &*%( me. Let me know if you are interested.
SF
ng
02-24-2004 16:02:39
 Re: Re: 335 MM or 445 MM UTILITY WANTED in reply to Scott, 02-23-2004 19:43:52
Yes Scott I am interested. Where are you located?
please email me. Thanks, NG
charles
02-23-2004 20:01:57
how much do you want for the 445 utulity? thanks charles
kevin hull
02-21-2004 13:59:53
I have a 445 hoe that doesn't need much to run. Needs a radiator and a water pump.
ng
02-21-2004 14:15:28
 Re: Re: 335 MM or 445 MM UTILITY WANTED in reply to kevin hull, 02-21-2004 13:59:53
Thanks for the info. What kind of shape is the rest of it in?
kevin
02-21-2004 14:32:22
 Re: Re: Re: 335 MM or 445 MM UTILITY WANTED in reply to ng, 02-21-2004 14:15:28
Front end needs a little tie rod, is bent,when loading it I popped the gear shift and it acts like there is somthing off inside. buckets need welded and hoe has a partial crack in boom that needs welded. Got it from a neighbor who used it up until the water pump went out in 1998 set in barn until 2003 when I got it from the family after he passed away in 2000.I have seen it run and it should start now without waterpump. Family couldn't find radiator or pump. I got it for the hydr's but never did anything with it.
BMG
02-22-2004 17:14:29
 Re: Re: Re: Re: 335 MM or 445 MM UTILITY WANTED in reply to kevin, 02-21-2004 14:32:22
Kevin,
Brian
kevin
02-23-2004 13:57:48
 Re: Re: Re: Re: Re: 335 MM or 445 MM UTILITY WANT in reply to BMG, 02-22-2004 17:14:29
Poland Indiana 35 east of terre haute and 50 west of indy just 2 miles south of I-70
