Minneapolis Moline Tractors Discussion Forum
MM BF fuel bowl
Bill
02-19-2004 16:45:28
I need a fuel bowl for my MM BF. Can anyone tell me what other tractor bowls may fit? I don't think the local Tractor Supply store will have any for MM. Thanks.
MikeinKY
02-20-2004 18:35:54
 Re: MM BF fuel bowl in reply to Bill, 02-19-2004 16:45:28
Bill, Any Auto parts house will have one. I just bought one from NAPA..
MikeinKy
02-20-2004 19:16:00
 Re: Re: MM BF fuel bowl in reply to MikeinKY, 02-20-2004 18:35:54
Bill, You should replace the whole assembly. Take the shut-off valve & sedament bub assembly off and match it up with one the same. My BF cost about $14.00. While you have the gas line off you can replace it with steel-rubber coated-flexable brake line. Get a straight piece and cut the ends off with a tubbing cutter. You can flare one end, and use new flare nuts because the old one become brittle and will crack when you tighten them back.
You can match the new line shape with the old line, but before you cut off excess line tighten one end on the carberator match other end to the fuel assembly before you flare the nut. I hope this may be of some help Good Luck!! Mike
