Minneapolis Moline Tractors Discussion Forum
HELP WITH MDL. YR, OF MINNY MO
FRANK
02-18-2004 14:40:02
CAN SOMEONE HELP ME TRY TO FIND OUT WHAT THIS TRACTOR IS. A FRIEND GAVE ME A SET OF NUMBERS OFF THIS MINNY MO AS FOLLOWS: MDL:#44x5283A4. HOUSING #10A1878. PARTIAL SERIAL 019...10... THIS WAS E-MAILED TO ME SO I DON'T DON'T HAVE A CLUE. ANY HELP WOULD BE GOOD. THANKS IN ADVANCE.....
BMG
02-18-2004 17:04:36
 Re: HELP WITH MDL. YR, OF MINNY MO in reply to FRANK, 02-18-2004 14:40:02
Frank,
Your friend has given the engine serial #s. The tractor serial # is located on a plate on the right side of the trans housing. From the model and partial serial # it looks like your friend has a U series tractor. Your model listed should read 4-1/4x5 283A-4. 4-1/4" bore, 5" stroke equals a 4 cylinder 283 cubic inch engine. The serial 019...10... is probably a 1948 to 1950 vintage if your dashes represent blank digits and the serial # is 10 digits long. If its only 8 digits long then it could be 1950 to 1953 vintage. The housing # is probably a casting # on the tractor. I don't know off hand what part that casting # is from.
Brian
FRANK
02-18-2004 19:07:07
 Re: Re: HELP WITH MDL. YR, OF MINNY MO in reply to BMG, 02-18-2004 17:04:36
THANKS BRIAN, THATS A BIG HELP. IT GIVES US A PLACE TO START.
