Minneapolis Moline Tractors Discussion Forum
mmr clutch
peter
02-08-2004 10:30:16
recently installed clutch recon. pressure plate and throw out bearing, it engages very hard but it does engage, have not had it running because I am rebuilding tractor, is it supposed to be this way? I am not familier with hand clutches the rest are all foot clurches thanks Peter
Kevin Moschenrose
02-08-2004 12:07:16
 Re: mmr clutch in reply to peter, 02-08-2004 10:30:16
I am not sure what you call hard. But the clutch should have some what of a snap to it as it breaks over center. Have you lubed the though out bearing? I wouldn't worry too much about it until you are ready to run the tractor. It needs ran a little to get everything reseated and the clutch surface "broke in a little". Some one here I am sure will tell me I am wrong. But that's my two cents.
