Minneapolis Moline Tractors Discussion Forum
mm445 1957radiator
russ
02-07-2004 19:56:09
looking for a replacement radiator , and have a question about a hydrlic leak under the radiator (vent hole).any help please !thanks
CARL
02-08-2004 17:23:01
 Re: mm445 1957radiator in reply to russ, 02-07-2004 19:56:09
IAM PARTING OUT A 445 AND HAVE A GOOD RADIATOR FOR SALE, MY EMAIL IS [email protected] AND I WILL FORWARD YOU A PICTURE
JK
02-08-2004 07:16:07
Russ,
There isn't supposed to be any hydraulic oil in the steering gear case. It should be contained in the piston sleeve assemblies and the steering control valve by seals and o-rings. If it is hydraulic oil coming out of the vent on top of housing, that means the case is full of hydraulic oil. Likely the o-ring/seal is leaking on one of the pistons because the sleeve is scored.
John
russ
02-07-2004 19:57:47
1957 mm 445
Frank (n.mi.)
02-08-2004 05:59:57
 Re: Re: mm445 1957radiator in reply to russ, 02-07-2004 19:57:47
Under the radiator? Is it leaking from the p.s. pump?
Frank (n.mi.)
02-08-2004 06:04:26
 Re: Re: Re: mm445 1957radiator in reply to Frank (n.mi.), 02-08-2004 05:59:57
Duh! I meant direction control box.
Kelvin
02-09-2004 19:12:35
 Re: Re: Re: Re: mm445 1957radiator in reply to Frank (n.mi.), 02-08-2004 06:04:26
John is right. If its leaking out where the steering shaft goes in, you've got a bad seal on the steering piston.
