Minneapolis Moline Tractors Discussion Forum
Compression Question
JKC
02-01-2004 08:39:54
This is probably a gross over-simplification of this question, but here goes: If an antique tractor starts rather easily after sitting for a couple weeks or so (pops right off), does that mean that one can assume it has good compression? I look forward to any responses. Thank you.
Kevin Moschenrose
02-01-2004 13:54:09
 Re: Compression Question in reply to JKC, 02-01-2004 08:39:54
Well yes and no! The true check is to run compression tests on it when it is cold and then after it has warmed up. I think it has more to do with timing along with many other variables as well.
