Minneapolis Moline Tractors Discussion Forum
engine swap
John
02-01-2004 06:39:29
looking at mm z with bad engine. have u302 engine will it bolt up to the z trans and front end thanks John
John
02-04-2004 17:01:01
 Re: engine swap in reply to John, 02-01-2004 06:39:29
Matt I,m in Kings Mountain NC John
Bill
02-01-2004 07:33:00
Not exactly the bolt patterns are the same but the front end has to be modified (cut out) for the 302s bigger pullys. The flywheel will be the issue at the back if you have a power unit flywheel for the 302 there is a chance it will work with the hand clutch otherwise you will have to maching the 302 flywheel to accept the clutch drive ring from the z.
Mopower
02-03-2004 09:57:07
 Re: Re: engine swap in reply to Bill, 02-01-2004 07:33:00
Hey Bill. Will the ZA flywheel just bolt on the U302 engine? I put together a RT wit a ZA motor and bolted the R flywheel right on, but I'm not sure about the U302. Not talking ring gear issue here, just flywheel studs and bolt pattern on the crank. I also am doing a 403 in a 47 U. I have to do some ring gear swapping and tranny grinding there.
Kelvin
02-01-2004 17:03:42
The other consideration is the water pump inlet location. Its on the right of the U302 engine, and on the left of the Z radiator. Gotta get the water to cross over somehow.
matt
02-02-2004 14:03:16
 Re: Re: Re: engine swap in reply to Kelvin, 02-01-2004 17:03:42
I have seen guys do it, it takes alot of work, just wondering what was wrong with the old engine and what are you going to with it? email me. thanks
John
02-02-2004 17:40:51
 Re: Re: Re: Re: engine swap in reply to matt, 02-02-2004 14:03:16
Matt all i know is the engine is stuck. have not got tractor home to check it out.if you need the engine call me and will talk. 704-692-2917 thanks john
matt
02-04-2004 11:07:11
 Re: Re: Re: Re: Re: engine swap in reply to John, 02-02-2004 17:40:51
I will call where are you located? thanks matt
