Minneapolis Moline Tractors Discussion Forum
Question on valves Jim P are you handy?
David Manring
01-31-2004 10:34:15
Yes are the valves the same on older Twin Cities tractors(the one like the 283-4)engine to the newer(UTS, U 605,403etc) ?
Jim Parisot
02-02-2004 09:49:05
 Re: Question on valves Jim P are you handy? in reply to David Manring, 01-31-2004 10:34:15
Hey David,
The simple answer is yes, they are the same. There were a lot of part numbers that in the end subbed to the same two numbers. But, scanning the parts books it seems that some of the low compression heads, for burning tractor fuel, used different valves. If you have any specific tractor or heads in mind let me know, I can look them up for you. Hope this helps.
Jim
david manring
02-02-2004 15:19:55
 Re: Re: Question on valves Jim P are you handy? in reply to Jim Parisot, 02-02-2004 09:49:05
Thanks Jim will get back if i need more info
