Minneapolis Moline Tractors Discussion Forum
585 information
Kevin
01-22-2004 18:22:51
I have a 2-150 white and i am looking to overhaul it. Wondering if anyone has any tips and places to find new parts. It is bored .030 over and I am thinking about sleeving it back to standard. any help will be apreciated thank you
HRS
01-24-2004 15:42:50
 Re: 585 information in reply to Kevin, 01-22-2004 18:22:51
Kevin, I just rebuilt a 585 bored it .060. In the process stumbled onto another tractor with 585, purchased it, have not even got home yet. Which I am sure it will need overhauled also. I also was sticker shocked on the AGCO pistons. So in within the past month I contacted a manufacture who will build me pistons with steel top groove, keystone or square rings, pins, keepers and rings for less than 60% of Agco piston list price. And I have just boxed up my sample piston to send to them. I am sure I could order more. I also can say I looked for a block for my last one and found one that had been dry sleeved it was terribly out of round and had slipped down probably .060 - .090. So I would have to advise no also. What bore size are you needing. I would sell you new Federal mogul .020 Main bearings worth the money
Tom
01-26-2004 15:12:07
 Re: Re: 585 information in reply to HRS, 01-24-2004 15:42:50
Any information you could provide on those custom made pistons would be great. Who is putting these together for you? Thanks.
freddy
01-25-2004 06:25:37
I am looking to rebuild a D585 in my A4T-1400. Could you tell me more about these pistons?
Mopower
01-23-2004 08:07:07
Kevin, I can connect you with a great 585 guy. Doug Henderson. He can tell you anything you need to know. I am pretty sure there are some serious issues with sleeving MMs and the 585 has it's quirks. I have had it done on a 336, but the motor won't be worked hard and it isn't together yet. E-mail me and I can pass on how to contact Doug.
Jim Hlasny
01-24-2004 17:35:20
 Re: Re: 585 information in reply to Mopower, 01-23-2004 08:07:07
What issues are there about sleeving an MM? Just curious. I just had one cylinder on my G706 done and I'm looking at having my Vista done the same way, both are 504 diesels. I had a step left in the bottom of the jug and had the sleeve ran in from the top then decked the whole thing. Do you think there still might be a problem?
-Jim
Bill
01-24-2004 19:37:39
 Re: Re: Re: 585 information in reply to Jim Hlasny, 01-24-2004 17:35:20
When you sleeve the 504 diesels they have a tendancy to crack to the center bolt hole in the deck. If you can find them get some G 900 blocks and bore them to the standard or oversize for the 504 they are the same block just not bored out as big. The 585 blocks are extremely thin down about the middle of the block and have been known to blow out at .060 when used with a turbo.
Mopower
01-25-2004 11:25:52
 Re: Re: Re: Re: 585 information in reply to Bill, 01-24-2004 19:37:39
Yeah, that is what I was refering to. I know there were some issues with sleeves moving and cracks from the step at the bottom of the cylinder. Yet, I know a few old machines that are just fine. Good luck in your projects guys and let everyone know how things turn out!
Ethan
