Minneapolis Moline Tractors Discussion Forum
Internal Hydraulic leak
Brain
01-22-2004 10:41:48
I have an early Jet Star that is leaking hydraulic fluid into the rear end. We are in the process of rebuilding the tractor so there is no gear oil in the differential yet. It drips down to the plug and leaks out from there.
We have gone thru the hydraulic pump and we are confident the seal in the pump is fine and the pump seems to be good.
Is there anything internally or otherwise that we are missing?
Dale
01-22-2004 12:18:18
 Re: Internal Hydraulic leak in reply to Brain, 01-22-2004 10:41:48
How are the seals where the hyd. assy. sits on the diff. housing, also you said the pump seals are good, are the pump mounting seals OK? Dale
