Minneapolis Moline Tractors Discussion Forum
g705 rebuild and injection problems
MORGAN HEATON
01-21-2004 05:27:51
Just bought a g705, the engine has some problems, the engine smokes white and doesn't run on all six. I have tried to crack the lines to find the suspected cylinder, It smokes on all six, and misses on number 4 and 6. It also slobers oil out of the valve cover breathers. My guess is the engine is worn out and has low compression, It will also start on one 12v battery also leading me to believe it has low compression. Can the fuel system inject so much fuel to wash the cylinders down and cause excessive blow by, Also I need a good source for a rebuild kit and any suggestions on possable ways to make some more power since I will tearing It down any way. Thanks
Morgan
Hoss
01-24-2004 20:18:15
 Re: g705 rebuild and injection problems in reply to MORGAN HEATON, 01-21-2004 05:27:51
Sounds like the fuel pump is out of time with the engine. They will run with the pump 180 out of time, but will do what you describe, and have low power.
