Minneapolis Moline Tractors Discussion Forum
NEST OF MINNIE U'S
CARL
01-19-2004 17:39:09
I HAVE FOUND AND PURCHASED 4 MM U TRACTORS, WHILE I HAVE A FEW SMALLER M M I DO NOT KNOW MUCH ABOUT THE U, ONE UNIT IS A UB SPL # 097011358 WHAT IS THE MAJOR DIFFERENCE IN IT AND THE UB # 05803491, & 05801567 WHICH SHOW TO BE 1953 MODELS, ALSO THERE IS A U #01106693, THESE ARE ALL PROPANE MODELS AND I AM LOOKING TO FIND NEW HOMES FOR ALL ANY HELP IN IDENTIFYING THEM WOULD BE APPRECIATED
freddy
01-20-2004 15:23:13
 Re: NEST OF MINNIE U'S in reply to CARL, 01-19-2004 17:39:09
How much for the ub special and do you have any pictures?
BMG
01-20-2004 14:26:03
Carl,
Your UB Special is a 1955 (only year gas/LP were made - 1475 total). The main difference is the front end. It had interchangable front ends. One tractor could be equipped with a narrow front, single front or adjustable wide front. The regular UB required different front nose castings to accomodate the different front end styles. The UB Special could also be equipped with power steering like what was used on the later 5 Star (which replaced the UB series). The Specials also had the flat 2 piece grill like the ZA/ZB or GTB/GB series of tractors. There are other minor differences between the UB and UB Special but I'd have to reference the parts books to remember them. Your UB # 05801567 is a 1953 model and # 05803491 is a 1954 model. Your other U is a 1951. The difference between it and the UBs should be quite obvious in the UB's higher operator platform, centered steering wheel and foot clutch. The UB Special is probably the most desireable to collectors out of the bunch given it was only made 1 year in gas/LP (it was made from 1955-57 in diesel).
Brian
Bill
01-20-2004 06:52:40
How much do you want for them?
moline
01-19-2004 19:08:59
Where are you located?
CARL
01-19-2004 19:32:58
 Re: Re: NEST OF MINNIE U'S in reply to moline, 01-19-2004 19:08:59
DALLAS TEXAS, TRACTORS 25 NE OF THE BIG D
CARL
01-20-2004 16:48:16
 Re: Re: Re: NEST OF MINNIE U'S in reply to CARL, 01-19-2004 19:32:58
IF YOU WANT PICTURES AND SPECFIC ON THE NEST EMAIL ME AT [email protected] AND I WILL TRY AND SEND YOU THE INFO
