Minneapolis Moline Tractors Discussion Forum
ZA Original Hydraulics
Rick
01-17-2004 20:33:49
My 1950 ZAE has had an aftermarket hydraulic bucket on it and I remove it. I would like to replace the original hyradulics on it. It has the lines coming of the left front air pump already I just need the rest of the stuff. Any idea where I could get the rest?
Augie
01-20-2004 21:30:20
 Re: ZA Original Hydraulics in reply to Rick, 01-17-2004 20:33:49
I've got a '51 ZA that's going to be used as an engine donor for my '46 R.
The hydraulics are all original, complete and working. Let me know if you're interested.
Kelvin
01-19-2004 18:14:13
Alan is right on: one thing to check is make sure your pump has a 3-bolt, 3-corner flange on the back of it. If it doesn't, then its not the original ZAE pump.
Alan
01-18-2004 17:48:05
I believe most of all the hyd. reservoirs on any MM's were the same (R ZA ZB UT UB GTB GB). The pump size, lines to hyd. res.(Eaton or Webster pump makes a difference also). and lines to rear of tractor were all different. Lever the same, rod length to res. was different. I may have an extra reservoir, and rod. Hope this helps.
