Minneapolis Moline Tractors Discussion Forum
za 3.75 bore
byron
01-17-2004 12:26:07
I recently installed 5 stat pistons into my motor and it started right up and the piston hit the top of the jug bending rod, now what do I do ,are the pistons any good to anyone let me know also what good are the blocks now with the big scores in them, what a mess now I need new jugs help Byron
Mopower
01-18-2004 16:13:57
 Re: za 3.75 bore in reply to byron, 01-17-2004 12:26:07
I modified a ZA motor to pull with and found a machine shop with a tool. They still left 1/16" at the top. I had 3-3/4"+.060 and LP heads to get good compression and i had to put a chamfer on the piston top edge and use a 1/8" thick block gasket so there would be no interference. Lost some compression from that. Good luck. My motor is ready to start up sometime. 227 cu in
Dieselbear
01-18-2004 09:35:12
you could always try the 3 3/4+60 pistons from Everrett Bros.I have them in my ZA. The com. height is correct. This time make sure whoever does the bore job knows what they are doing Glenn
Spuds
01-18-2004 08:33:55
byron, sounds to me that who ever bored your cylinder didn't have the tool to bore the top leaving a ridge. A special tool is needed to complete a bore job on a ZA motor.
Check to see if you have this ridge, if thats ok check your compression height.I.m about to do this bore to my Za 206
Spuds
John G
01-18-2004 11:55:00
 Re: Re: za 3.75 bore in reply to Spuds, 01-18-2004 08:33:55
I had my RE101A blocks bored to 3 3/4" at a MM dealer, they let the NEW GUY do it and he left 1/4" at the top unbored. Found it when I was rolling it over to install the blocks onto the c/case. He told me that the rings didn't go that high!! Just remember, half of the DOCTORS graduated in the bottom half of their class!!!
dlp
01-18-2004 15:34:32
 Re: Re: Re: za 3.75 bore in reply to John G, 01-18-2004 11:55:00
I find it amazing that there are more incidents exactly like this. When I had my blocks bored, they left one cylinder with about 1/4" lip at the bottom. Quite a problem when they were bored .180" over!
Kevin Moschenrose
01-17-2004 15:54:39
Don't give up so easy on them. The blocks can be sleeved I have seen this done and work great. I would have thought that the sleeves would drop out the bottom but they don't. Only thing is not everybody would tackle this project. What kind of pistons did you put in it? Also just what is it that you are tring to do here with this motor? If you want to email me that's o.k. too.
Jim Parisot
01-17-2004 15:24:38
byron,
Only consolation is that scrap metal prices have exploded in the last few months.
Jim
