Minneapolis Moline Tractors Discussion Forum
UTU push rod length
Chris
01-16-2004 19:33:02
I am switching heads on my UTU from 4209 heads to 4210 heads. Since the 4210 heads are a bit 'shorter', can I use the same push rods that were used with the 4209 heads? The 4210 heads are about an 1/2 inch shorter, but is there enough adjustment in the rocker arms to account for this? If not, is there a good way to shorten the push rods a bit? Thanks.
E J
01-18-2004 12:09:10
 Re: UTU push rod length in reply to Chris, 01-16-2004 19:33:02
When I did the same I had to change head bolts oiler tubes and push rods.A 4209 is 5" tall,4210 is 4 17/32" more like 3/4" 4209 has 5.5:1 comp. 4210 has 6.95:1 comp.
