Minneapolis Moline Tractors Discussion Forum
MM GTB engine parts
Mike
01-15-2004 11:31:28
I'm just getting started on it.The engine is stuck.Is there a place to get oh kits for the 403 motor or good used parts if I need them?
Mike
01-18-2004 14:52:31
 Re: MM GTB engine parts in reply to Mike, 01-15-2004 11:31:28
I tore it down.The engine is totally scrap!It must have just been overhualed.There was absolutely no oil anywhere!One sleeve was good.The rest full of rust.Now,plan B a 3-71 detroit.
Andy
01-19-2004 13:30:05
 Re: Re: MM GTB engine parts in reply to Mike, 01-18-2004 14:52:31
Don't scrap the motor! the crank, cam and heads my be just fine(after grinding). Plenty of people looking for those parts. they aren't making any more.
Andy
01-15-2004 14:39:12
I have some misc 403 engine parts,(crank, blocks, heads). try welters for new parts.
Fran
01-15-2004 18:28:11
 Re: Re: MM GTB engine parts in reply to Andy, 01-15-2004 14:39:12
I need a good standard piston and set of rings for a GTB. Also need the water pump shaft that drives the distributor. Do you have any of these items?
Andy
01-17-2004 08:05:43
 Re: Re: Re: MM GTB engine parts in reply to Fran, 01-15-2004 18:28:11
I think I have some aluminum GB pistons, not sure if they're stock or not, I'll check.
