Minneapolis Moline Tractors Discussion Forum
Burned M5 Diesel for Parts
Curtis
01-14-2004 14:20:53
Just wanted to let you M-M guys know that I've advertised a 1960 M5 Diesel in the classified ads. It was a good running tractor prior to being burned. Now it's a parts tractor.
Al
02-28-2004 06:34:51
 Re: Burned M5 Diesel for Parts in reply to Curtis, 01-14-2004 14:20:53
I need a hydraulic pump, shift lever, rear wheels
for an M5. Do you still have it? I am in Wisconsin what State are you in. I may be interested in the whole tractor
Glenn
01-14-2004 16:09:14
I'd be interested in the heads if they are ok. are you going to part it or sell it as is? Where are you located? Also part# please Thank, Glenn
Curtis
01-14-2004 20:53:51
 Re: Re: Burned M5 Diesel for Parts in reply to Glenn, 01-14-2004 16:09:14
Glen,
The tractor actually belongs to my grandpa. I am currently attending college in Lincoln, but the tractor is located at Leigh, NE. I am not sure that the heads are OK, but after the fire the engine oil was still OK and the bottom radiator hose was still intact. The fire was pretty hot, so the tractor looks bad. The tinwork is all warped and unusable, but given that the oil and antifreeze were still in the engine, I think that they heads, crank, etc should be OK. If you want more information, you can call my grandpa:
Lawrence Hillen
(402)487 3307
Thanks for your interest.
