Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline Sickle Mowers
JC
01-11-2004 22:09:39
I am considering buying an old MM sickle mower to restore and mount on back of my ZTU. (I would consider a belly mount mower if they are best)
Which model of MM mower is the best, as I will use the mower now and then. Please be as specific as possible.
I have absolutely no experience with MM mowers, in fact, I have never even seen one, so your recommendations is all I have to go by.
Thanks for your help.
Loren
02-07-2004 23:25:27
 Re: Minneapolis Moline Sickle Mowers in reply to JC, 01-11-2004 22:09:39
I have a semi-mounted Moline mower. It's pictured in the Implement Photos Gallery. Hope the picture helps.
It is for sale.
Jon Holt
01-29-2005 13:18:22
 Re: Re: Minneapolis Moline Sickle Mowers in reply to Loren, 02-07-2004 23:25:27
I was wondering if you still had the mower that was pictured in the photo and also what model it was if you know. I think I have one just like it that I use for cutting hay and am needing parts, a parts mower or a back up
JC
02-08-2004 22:00:29
Where are you at and where is the picture? Can't find it in photo gallery.
Thanks
Loren
02-09-2004 12:11:39
 Re: Re: Re: Minneapolis Moline Sickle Mowers in reply to JC, 02-08-2004 22:00:29
Go to Implement Photos in the Galleries column to the left. Enter "Loren" in the search box -this will show all of the Implement photos I've posted. I'm located in central MN.-9 miles south of Mora,Mn or 60 miles North of Mpls.MN. e-mail [email protected]
Kelvin
01-12-2004 18:17:24
I'm only aquainted with the model MO sickle mower. It is a semi-mounted mower with one tail wheel which MM aquired when they bought BF Avery. It has been some trouble, but fairly reliable for a gizmo that shakes like crazy. We've used it yearly for almost 50 years. I guess its exactly 50 years, because it came with the '54 ZB.
MM's own sickle mower that would be same vintage as your ZTU was the UM 4 and UM 5. I am unaquainted with them.
Then there is the model S or SO. I've never seen a picture of one of these mounted on a ZTU.
steve
01-18-2004 05:59:50
 Re: Re: Minneapolis Moline Sickle Mowers in reply to Kelvin, 01-12-2004 18:17:24
the SO was a belly mount have seen them on R's but not on Z's, not common The UM-5 had a flaw the brace went into a casting and the casting would break if you hit something with the bar probably OK if you don't hit anything!
